Setting MC dwell
Old Sep 15, 2000 | 03:16 PM
IROCKZE's Avatar
Car: 85 Mercedes 500SEL
Engine: 5.0 DOHC
Setting MC dwell
Hey all,
Ok here is my dilemma. Trying to set the dwell to 50% on my q-jet (at idle) and all I can get it to do is go across the scale. It starts out at like 75% then slowly goes down to around 10%. (takes about 1 minute to do this) I give the throttle a little blip and it goes the other direction. Hit the throttle again and the same thing. What gives? By the way I am using my auto x-ray to look at the dwell in a percent value, put I do have an analog dwell meter too if it's better to use that. Any help is appreciated.
Old Sep 15, 2000 | 04:48 PM
Biochem's Avatar
Car: 2002 SOM z28
Connect dwell meter to terminal B on the enrichment solenoid connector.
Allow engine to reach operating temp. The dwell meter should vary while resetting base idle if neccessary.
Set parking brake, put into DRIVE.
Dwell meter should fluctuate between 10` and 50` on the 6 cylinder cycle, the ocilloscope should indicate 15%-85% duty cycle.
Adjust idle air bleed screw in 1/8th turns until 251`-35`. Optimum is 30` (50% duty cycle). Allow system to react between adjustments.
If this doesn't work, then you have to adjust the idle mix screws...
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock... all the suspension stuff... 9-bolt posi disk is in... K&N filter... 93 octane...
I got the GO... I need the SHOW... Interior is next!
Old Sep 15, 2000 | 05:00 PM
IROCKZE's Avatar
Engine: 5.0 DOHC
Thanks Biochem! I will give it a shot.
82tabird
Dec 21, 2015 10:22 PM
lt1z350
Sep 29, 2015 01:50 PM
hydrolic144
Aug 29, 2015 04:14 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Aug 24, 2015 06:52 AM
mustangdmurder
Aug 21, 2015 07:17 PM
