Lubricating a carb
Old Mar 22, 2002 | 05:01 AM
Nemesis's Avatar
Car: Modified 83 Berlinetta
Engine: 350 - 300hp
Lubricating a carb
Is it good practise to lubricate the internal moving parts of a carb eg where the AV's pivot etc? If so, what is appropriate to use?
Old Mar 22, 2002 | 11:51 AM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
The parts in a carb move so slowly compared to other parts of the engine... not even worth lubricating... If the carb is gunked up to the point where you might consider lubrication... it's time for a rebuild. While rebuilding the carb just "soak" the metal parts of the carb in a carb cleaner solution for a few hours... should make everything nice and pretty again.
Old Mar 22, 2002 | 05:55 PM
Damon's Avatar
Never lubricate a carburetor linkage/part. All it does is attract airborne dirt. They are designed to run dry and clean.
Old Mar 24, 2002 | 05:30 AM
Nemesis's Avatar
Engine: 350 - 300hp
Thanks, yeah I wondered if you should use a dry lubricant like graphite, but will leave it alone Thanks guys.
Old Mar 24, 2002 | 03:43 PM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
I spray the linkage with carb cleaner to remove any dirt . That's about it.
Old Mar 24, 2002 | 06:23 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Using silicon spray on the linkage won't hurt and might even help if things are binding.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
