Is there a way to convert a comp-controlled q-jet into a non...
Car: 2002 SOM z28
Can I convert the computer controlled q-jet that came off my 84 305 into a non-computer controlled version? I guess removing the TPS wouldn't be an issue, but what about the MCS? I have a Holley on there now, but would like to have a backup if something ever went wrong...
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock... all the suspension stuff... 9-bolt posi disk is in... K&N filter... 93 octane...
-=ICON Motorsports=-
Transmission: 4L80E/4L80E
No.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.73 unlimited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, TBD heads, exhaust, paint, etc.).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Car: 04 GTO
Transmission: M12 T56
Hehehe, actually, i imagine so. It doesn't seem like it would be too hard to make an analog device to drive the MCS based off a VAC sensor. Not too hard at all. A couple of timer circuits to give frequency and dwell, and a VAC sensor to bleed a cap to control the dwell. The trick would be tuning.
As far as using it as a purely mechanical piece, no that can't be done.
...ed
...ed
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you were going to do all that, you've just built a computer anyway, so the answer is still no.
1984 Silver Z28, decked 383 cid 4 bolt, ARP Fasteners, 2 1/2" Cowl Induction Hood, 600 cfm Performer Carburetor, Torker II Intake, Performer RPM Heads, XE268H Cam, Magnum Roller Tip Rockers, MSD6AL Ignition, Blaster2 Coil, Recurved HEI Distributor, 700R4, TransGo SK, 2.73:1 Limited Slip Dana 44, Terminator Headers, Custom 3" TIG Welded Stainless Exhaust, Flo-Pro Twister Muffler, 4 Wheel Disc Brakes, Oil Cooler
Thirdgen89GTA
Nov 26, 2015 11:04 PM
