need some help picking rods and hangers....
Old Dec 29, 2000 | 12:34 AM
86IROC's Avatar
Hey guys, well I have some money from xmas so I thought I'd buy some new rods and hangers. My question is I have no clue what ones to get. My set up is in my sig. So I'm trusting you guys to help me out here. Here's the site (http://www.carbs.net/rodshang.asp) I'd appreciate if you guys would help me out here. Thanks in advance.
305 LG4, 5 speed, 4 wheel disc, new rear brakes just put in, 3.23 possi, dynomax cat back, Accel 8.8 wires, Accel performance cap and rotor, K&N, Mobile 1 fluids, and soon new rods and hangers for my q-jet!
Old Dec 29, 2000 | 07:42 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I am happy with the g hanger and dr rods,summit sells the hanger under edelbrock and gm has the rods.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Jan 1, 2001 | 08:07 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'm not a racer type, so I'm content with AH rods and a G hanger. You might contact Damon at DNickle614@aol.com. He can provide a lot of experience as well as a list of secondary metering rods and their part numbers. Very helpful guy.
JamesC
Hotrodboba400
Dec 10, 2019 07:07 PM
TOMcat GTA
Sep 15, 2015 09:31 AM
Street Lethal
Sep 7, 2015 01:09 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
