mods for an 1850
Old Mar 29, 2002 | 08:41 AM
fordsuks91's Avatar
Car: 89 Formula
mods for an 1850
Does anybody know mods you can do to a holley 600 carb? I bought one for $20 that needs a rebuild. Since im gonna have it appear i was wondering if there was anything i could do to it. Im relitively new to carbs but i heard that you can up the cfm if you put bigger jets in. Is this true? Thanks for your help, its appreciated,
Danny
Old Mar 30, 2002 | 08:28 AM
fordsuks91's Avatar
Car: 89 Formula
Can ANYBODY help me out??????????
Old Mar 30, 2002 | 05:33 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Nothing really big to mod on an 1850. You could get a secondary metering block to replace the metering plate. I cant seem to find the part number off hand, that would give you some adjustability for the secondaries. Other than that nothing major can be done the carb is good as is.
Old Mar 31, 2002 | 09:03 AM
84zeddd's Avatar
That carb should work well with your current set-up.You might
try a lighter secondary spring when you get your gears put in.
Old Mar 31, 2002 | 11:50 AM
Jester's Avatar
you can't change cfm with jets...doesn;t work like that.
Get a quick change secondary kit, those are handy. Run it, and see if it's rich or lean in the secondaries. If it is, get a 4150 kit to tune it. Other than that..the carb works very well as is.
FWIW, I ran a 1850 600cfm on my 305 for a few years. I didn't have to tune the secondaries, and I ran my best times with the stock secondary spring. So you probably don't even have to do that much.
starliner
Feb 9, 2016 08:18 PM
Quzyle
Oct 15, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
