Sticky Carb
Old Jan 12, 2001 | 06:19 PM
Skip Howard
Guest
Posts: n/a
Sticky Carb
This seems too simple but I'm at a loss. My throttle sticks at around 800-1200 RPM on my electronic Q-Jet. I can push it down to the idle stop with relative ease and I have the fast idle adjust all the way out 'cus it has problems disengaging(sp?). Are there worn bushings or the like I'm missing???
Old Jan 25, 2001 | 08:45 PM
Nordbert's Avatar
I hope your Q-jet problem is this simple.
Have you checked the lever that sticks up
on the driver's side of the secondary throttle shaft? If the secondaries are not
fully closed the idle will be fast, but usually it will also be a little rougher than
normal.
RedLeader289
May 28, 2019 01:47 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
lanceflame44
Sep 25, 2015 12:28 PM
