Good sized carb for a powerful 350 or 383
Car: 1991 Galant VR4
Engine: 2.0L 4G63 Turbo
Transmission: 5sp transaxle/transfer case
What is a good sized carburetor for and 350 or 383? 750 CFM?
Transmission: 4L80E/4L80E
You probably haven't received any responses because your question is too open-ended. Really need to know more about the combination like cam, heads, intake, exhaust, transmission, use, etc.
For a low-RPM torquing 350, a 600 would be fine. Chevy uses a 750 Holley to rate their ZZ4 at 355 HP. 383's would use a slightly larger carb, but certainly nothing like an 850 unless the RPMs are sky-high.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, WP 305 heads ported & polished, Hooker headers & y-pipe, hi-flow cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Car: 4
Engine: 6
Transmission: 5
Look at www.demoncarbs.com and check their recommendations for carb vs. motor. I think a 750 is what they would pick.
ICON Motorsports
ICON Motorsports
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
My 383 worked great with a Speed Demon 850 but I was also shifting at 6500 rpm. The 850's now on the big block and it may not be enough. It really depends on your combination of parts.
I've also seen an Altered dragster with a 377 engine and a 650cfm carb run mid 9's.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.662
theshackle
Sep 17, 2020 08:26 AM
NinjaNife
Aug 23, 2015 11:49 AM
knight72
Aug 10, 2015 09:32 PM
