Rich, Lean, or Something Else?
Old Feb 12, 2001 | 11:09 PM
mcconahay37's Avatar
I'm running a Holley 600 cfm 4bbl carb on a relatively mild 350 in an 82 camaro. My problem is that when I mash on the gas, the car hesitates, lurches forward, and then launches. From a stop it's the worst. After the initial bogging, it accelerates like the devil. The problem gets a little better as the car warms up but never really goes away. Is this more indicative of a rich or lean condition or something else entirely?
82 Camaro:
350, Erson cam, ported heads, Crane Hi-6 ignition, Accel supercoil, Comp Cams 1.6:1 rocker arms, Turbo 350 tranny with 2500 stall.
Old Feb 13, 2001 | 12:40 AM
The ODB's Avatar
usually means a lean spot. You may need more acellerator pump shot. Sometimes a 4-hole carb spacer will help some too.
ODB
Old Feb 13, 2001 | 12:22 PM
82camaro's Avatar
Car: 82 camaro SC
If the hesitation is immediate, I would check the accelerator pump. Also, if you have vacuum secondaries, make sure they aren't opening too soon.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Feb 13, 2001 | 03:08 PM
The Jegs part # for my carb is 510-O-80457S. It has vacume secondaries and electric choke. How do I go about adjusting the accelerator pump or do I have to replace it? Also, what would be too soon for the secondaries to open?
82 Camaro:
Old Feb 13, 2001 | 05:06 PM
84TransAm's Avatar
Hey, i'm getting that too (in 2-3 business days). I've worked on 2 quadrajets before, and to get to the accelerator pump we had to tear down the carb. Opening the Quadrajet was pretty straightforward, and I hear that the Holley is real easy. As long as there aren't any Torx screws, you can do the whole thing with the flat edge, or phillips head screw drivers, and plenty of carb cleaner.
As for adjusting vs. replacemnt, the Quadrajets are replaced and cannot be serviced externally, i don't think that will help much with a Holley but it may give you an idea.
--Steve S--
1984 Trans Am 305 LG4, 5 speed
Daily Driver, Flowmaster 80 Series
[This message has been edited by 84TransAm (edited February 13, 2001).]
F-body-fan
Jan 12, 2023 01:49 PM
Mark_ZZ3
May 24, 2018 01:02 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
Luigytico09
Oct 1, 2015 08:46 AM
Jk_Under
Sep 8, 2015 08:13 AM
