Are the Carter parts the exact same as Edelbrocks?
Car: 1985 Trans Am
Axle/Gears: 3.70
Do both use the same jets and rods? It seems like the Carter kit has more in it then Edelbrocks. How about the rebuild/gaskets kits?
TIA
TIA
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
from what i have seen and heard the only difference between the carter and edelbrock carbs is the carter uses metal bushings on the throttle shafts so i'm assuming the jets and rods are the same.
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
i think the accelerator pump is a different size. my buddy had a carter and an edelbrock apart, and had a kit for one and was gonna use it for the other, which one i dont remember, but I think he said the diameter of the accelerator pump was different, and that you couldnt use the the same kit for both carbs, i could be wrong though. its been a while. lil jay
LT1Formula
20
Nov 14, 2015 12:02 AM
86IROC112
Aug 17, 2015 02:00 PM
