What fuel pressure....
Old Feb 22, 2001 | 10:54 PM
PPonU4Me's Avatar
What should me Fuel pressure be with my edelbrock carb 600cfm. If I punch it, and get into the "R's", it just cuts out or sputters bad.
'87 Camaro Iroc-Z
'92 350 .040-over
Mild Cam
700R-4 w/shiftkit only.
Edelbrock Perf. manifold and Carb(600cfm#1406)
GM HEI upgraded with Accel parts
TBI truck Heads
Old Feb 23, 2001 | 10:18 AM
The ODB's Avatar
watch your fuel pressure as you drive at WOT.
You should have approx 6psi at idle, and not go much below 5psi @WOT.
also, after driving pull the air-horn off and check the fuel level in the bowls. If it looks low then you may need to adjust your floats a bit higher.
ODB
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
