Holley
Old Feb 16, 2001 | 11:57 AM
Blue92's Avatar
Holley
So does anybody have any thoughts on the new Holley Street Avenger Carb. It seems like it has addressed a lot of the concerns people had about Holley's in the past.
Old Feb 16, 2001 | 02:25 PM
ERIC'86IROC's Avatar
Yeah, I wish I could trade my barely used 3310(750cfm VS) in for a 670cfm Avenger. Looks like similar features to the Road Demon which I didn't get because it is only 625cfm. My carb is working quite well but I think the Avenger would improve my throttle response.
350 Vortec, forged flat-tops, CompCams XE268, Edlebrock RPM, Holley 3310, TH350 w/Holeshot 2400, 3.23 posi, Heddman shorties, HEI
Old Feb 17, 2001 | 12:01 PM
GOLD85's Avatar
me and my buddie think is a freakin rip of. its still a same old holley. i mean the flots are always pre adjusted from the fasctory. always come with a seconday fuel filter but every on take them out anyways. since 92 holleys have had power valve blow out prtection. the only think good aboot it is that it has quick change springs and lots of vacum ports. its still just the same old holley carb most of have. oh and the sight plugs can be bought from holley or moroso. just MY two cents
when the green flag drops the bull$hit stops
Curent: 350,performer RPM intake ,650dp, 700r4, headers, 3inch exhast
Spring 01: 406, Comp 282 solid cam, 2400 stall converter, every thing else the same.
Old Feb 22, 2001 | 09:28 PM
Blue89RS's Avatar
I hope the new avenger carbs are good. I just ordered one today and it will be here in a couple weeks. the car is away for the winter so it will be a couple months before i can tell you what i think about it and how it performs. Oh yea and the are alot more $$$, so i guess i'll see if it was worth it.
Old Feb 25, 2001 | 10:41 PM
Fast-Formula's Avatar
I bought one cause my Edelbrock kept giveing me fit's. First It's not ready to run right
out of the box.I had to change the Vac. Sec. spring to help with the throttle response.Second it cost me $380.00 w/tax locally.I could have bought a regular vac.sec. Holley carb and then bought a quick
change vac. sec.kit,Clear fuel bowl plugs and basically had the same carb for less money.I like the carb but don't think it was
worth the money.Mine is the 670 model.
Also the float level is not pre set.Mine was
rite for the front bowl but above the clear
site plug in the rear bowl and I can't get it to go down for $hit.Plus the electric choke is acting up.Better than a Edelbrock but not worth the money. I'm looking to trade it for a 650 dbl.pmpr.
RaverRacerX
Mar 17, 2026 01:49 AM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
