idle miss
Old Apr 3, 2002 | 07:56 AM
1986redbird's Avatar
idle miss
hey guys,
i'm getting a minor miss (just enough to be agrivating) at idle,
i have checked the tps, map sensor, etc,etc. I have also rebuilt the carb and I know the float is right, i have the IAB adjusted per the dwell meter and the idle mixture screws are about 1 1/2 turns out,i have epoxied the plugs in the bottom of the bowl, the motor runs really well except for idle.
I disconnected all the vacuum line from the carb and capped the ports (all except the map sensor i left that connected) and still have the miss, tried the starter fluid trick with no help.
I think maybe a problem with the intake gaskets, is there any way to check these without removing the intake ?
P.S. the motor is new (5,000 miles)
eightsixseven
Dec 16, 2024 01:50 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Eric2ndGen
Nov 5, 2015 01:51 PM
86CamaroDan
Sep 29, 2015 10:08 PM
beast94
Aug 20, 2015 06:44 AM
