Rods and Hangers
Old Mar 1, 2001 | 03:53 PM
Aaron87SC's Avatar
Rods and Hangers
I have a mostly stock LG4 and I have no cash. I'll hopefully be adding a catback and along with my dual snorkel air cleaner (K&N)and hypertech chip, I was wondering if another cheap mod I could do was to change my rods and hangers (I have the Q-jet). If so, what do you think the best ones would be?
[This message has been edited by Aaron87SC (edited March 01, 2001).]
Old Mar 2, 2001 | 02:10 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I can't say my choice is the best, I'm not a rodder by any stretch of the imagination, but I'm using AH rods with a G hanger. Very, very nice compare to stock. I bought the rods from GM and the hanger from Edelbrock.
JamesC
Old Mar 4, 2001 | 01:55 AM
Galen W. Rouse's Avatar
You can loosen the secondary air valves along with the vacuem diaphram to allow them to open quicker. The AH rod is probably OK but I would prefer a CP or DR rod. They are thiner across the taper and usually will allow a crisper part throttle acceleration. If the exhaust is freer flowing, you may try CY or DA rods to compensate for the primary sides leaness. On my 79 Z28, I run the primary side lean for crisp response, and richen the secondary side for full throttle power, as that is where a majority of the fuel Delivery comes from anyway. Qjets I found are treated such as two seperate carbs, Primary/Secondary. You can adjust the APT on the primary side to slighly richen the low end. Doug Roe's Quadrajet Book on the HP Books Label is a very good source for information, along with articles I have seen by Damon. You may also upgrade the ignition w/ spiral core wires, and a CD (MSD/Crane/Holley). Anything that will increase eficency and torque will benifit you.
67 Camaro 10.5 tire street car 11:1 383 t350 4800 stall 4:30 9" 10.5X30 Mt ET Street 10.50'2@128 on motor
79 Z28 Restored w/9.17:1 383 Ca. smog legal S/RTorquers,modified by me Qjet,stock exh manifolds,3:73's 13.20's@103
Old Mar 5, 2001 | 01:42 PM
Aaron87SC's Avatar
Anybody else?
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
