Fuel Pumps?
Old Mar 22, 2001 | 03:19 PM
Demon Z28's Avatar
Car: 2001 Camaro SS
Engine: Almighty LS1
Fuel Pumps?
I guess its the right place to ask... what fuel pumps were used on Carb'd camaro's? I've got a crate 350 in my 83 and I'm looking to replace the fuel pump in a bit... any ideas?
Old Mar 22, 2001 | 04:07 PM
SUPER-SPORT-CHEVY's Avatar
Just a stock mechanical fuel pump with 3 connectors 1 from fuel tank 1 to carb amd the other back to the fuel tank. if you go to an electric like most people, make sure to block off the old mechanical pumps hole but leave the pushrod in "oil pressure issue or something" and use a rotary style electric pump "more reliable"
85 Camaro RS T tops 350/350, stealth intake. holley street avenger 670. ported 58cc heads. comp magnum 270H cam,Crane 1.6 roller rockers,edelbrock accu-drive, MSD 6 series ignition on HEI, K&N extream air cleaner, true dual exhaust with 18 inch glasspacks.
82 Firebird 305/250 action plus intake, accel distributer with ccs 8mm wires foam air filter.
The only "cat" i have uses the litter box
Old Mar 22, 2001 | 04:32 PM
Demon Z28's Avatar
Car: 2001 Camaro SS
err... mmkay... any brands I should go with?
Old Mar 22, 2001 | 06:33 PM
bosh make a good fuelpump or if you want to stick with stock use a holley or edelbrock street pump. you can get any of these pumps at a local parts store.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
