2 carb questions
Old Mar 20, 2001 | 08:30 PM
Alan84TA's Avatar
2 carb questions
First on my '85 the other day I was driving and I let off the gas but the throttle stuck where it was with my foot off the gas until I hit it again then it was fine.
Second this is not thirdgen but simmilar problem on my '77. Car runs fine until it warms up then it does the same thing with the throttle sticking or whatever. Let off the gas but it is still going the same rpm. However when I put the brake on it will bog and surge a few seconds and die. I have to wait a few minutes and it will run a few miles and do the same thing.
Both are stock q-jets the '85 is a L69 and the '77 is a Pontiac 400..
THANKS!!!
Old Mar 20, 2001 | 08:48 PM
FlashGTA
Guest
Posts: n/a
Get some carb cleaner and clean all of the linkages real well. Make sure your throttle return springs are working right, replace them if you need to or add a backup spring to ensure the butterflies close when you let off the gas.
Old Mar 27, 2001 | 11:41 AM
87formula's Avatar
Do exactly what was said above an dalso make sure your gas pedal is not hitting the floor mat and sticking, make sure that your springs are not broken...
<font face="Verdana, Arial" size="2">Originally posted by Alan84TA:
THANKS!!!
</font>
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
