Carb Jetting Recommendations (need help)
Old Apr 2, 2001 | 04:14 PM
89Formula#42's Avatar
I've got a 350 with vortec heads, ~9:1 compression, and a comp 268 cam. I'm running a qjet on top of it, and have a big bog when I mash the gas, if I ease into the throttle it does alright.
I realize the carb needs some tweaking. What do you all recomend for primary/secondary jets on said motor? It should be making ~300-350 hp with the setup I've got.
Please respond and recommend, I've never rebuilt a carb yet.
Old Apr 2, 2001 | 06:52 PM
The ODB's Avatar
you don't fix a bog by rejetting.
work with the accelerator pump. A stronger spring on the rods might help some too.
RedLeader289
May 28, 2019 01:47 PM
efiguy
Sep 27, 2015 01:30 PM
Damon
Sep 26, 2015 04:29 PM
lanceflame44
Sep 25, 2015 12:28 PM
