Stalling
Old Apr 9, 2002 | 01:54 PM
Sandman's Avatar
Stalling
My Trans Am keeps stalling when I put the car in drive or reverse. When I start up my car starts up fine and runs well, when I put the car in drive or reverse the car stalls, the RPMs go up and down and then it stalls but it does not stall in park or neutral. I had my carb rebuilt, the problem stopped for a couple weeks and then the problem came back. Does this problem sound like a carb problem, if so what should I do. Also the guy that rebuilt my carb said I had a small vaccum leak might that be the problem? I need help bad, if I don't get the car up and running my parents are going to make me sell it.
Old Apr 20, 2002 | 05:05 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
could be an ignition problem...wires ,plugs ,cap ,coil pick=up coil
check these...
Old Apr 20, 2002 | 10:03 AM
82camaro's Avatar
Car: 82 camaro SC
Where is the vacuum leak? Why didn't the mech. fix it? Fix the vacuum leak. That can cause your problem(lean idle mixture). Richen up the idle mix a little if it still stalls after you fix the vacuum leak.
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
amcnellis
Sep 16, 2015 04:16 PM
