52mm throttlebody
Old Apr 14, 2001 | 11:55 AM
4SPEED's Avatar
52mm throttlebody
would it be overkill?
gutted maf/air box, k&n, msd, accel cap/wires, ported plenium, stock manifolds but cat is gone and have 3.5 exhaust w/flowmaster, relocated mat, water/alochol injection, 1.6 rockers
Old Apr 14, 2001 | 02:10 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
This should have been posted in the TPI section but since it's here I'll reply!!
You don't need the 52mm throttle body if you have the MAF and the stock chip because the ECM limitations will only allow the MAF to flow approx. 440 CFM (255gm/sec) max even with the gutted MAF! You actually MIGHT get close to 500 CFM with the gutted MAF!! However, the stock INTAKE is the most restrictive part on the TPI system and if you haven't done any work to it at all then the extra air that the 52mm throttle body will allow through is useless!! You said you ported the plenum but didn't say anything about the intake!! Until the intake is modified just stick with your stock 48mm throttle body!!
Old Apr 16, 2001 | 09:55 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
moving to TPI
Fred SS
Oct 12, 2015 11:27 AM
Magman
Sep 14, 2015 01:30 AM
Chris Sartori
Aftermarket Product Review
Nov 11, 2001 02:30 PM
vortech305
May 19, 2001 03:38 PM
Daz
Jul 23, 2000 08:11 AM
