HELP!!
Old Apr 22, 2001 | 08:35 PM
Hankman55's Avatar
From: Waltham, Massachusetts U.S. of mutha fuckin A
HELP!!
My carb is leaking fuel. What can i do short of replacing it. Its a holley on my 351W Ford smallie
Old Apr 22, 2001 | 08:47 PM
83CrossfireBomb's Avatar
how bout a rebuild kit?
oil burning
brake squealing
2 minute painted
305 rolling timebomb
Old Apr 23, 2001 | 08:38 AM
350HOZ28's Avatar
A rebuild kit would be a good,(and cheap) idea. It depends on where it is leaking fuel at. More than likely it is a metering plate gasket on the primary side. Make sure to check all screws and fuel lines for loose connections.
Formerly known as 1984L69Z28
1984 Z28 - L69 optioned, 350HO w/ Trick Flow Heads, Drop Forged Lunati Crank, Crane Cam and 1.5 Roller Rockers, Stock Z28 Intake Manifold, Highly Tweaked Rochester Carb(700cfm), K&N Filter, ThermoMaster Chip w/ 160 Stat, Comp Headers, 3" Stainless Dual Exhaust w/ no Cat & Dynoflow Muffler, 4 wheel disc brakes, etc....
God bless us father, son, and holy ghost....whoever goes the fastest wins the most!!
Old Apr 23, 2001 | 03:00 PM
Hankman55's Avatar
sounds like a plan. thanx for the help.
