carb question
Old Apr 2, 2001 | 12:42 AM
bubbz89's Avatar
Car: 1990 RS
Transmission: TH-350
carb question
i was wondering about a myth i heard about getting someone to tune in your carb to get through emissions. i am looking into a 75 camaro but if i get antique tags then i can only drive on sundays. any help is appreciated.
Old Apr 2, 2001 | 07:25 PM
The ODB's Avatar
do you have a question?
Old Apr 5, 2001 | 10:20 PM
x5finger's Avatar
<font face="Verdana, Arial" size="2">Originally posted by The ODB:
do you have a question?</font>
Anyone this stupid couldn't have registered on this board all by his/her self.
In reply to bubbz, this is true. A good carb tuner can bring down your emissions a good amount, within reason. A double pumper on a 454 isnt going to pass. You'll still need a catalytic converter, and a good combo.
I think your best angle is to re-check your local laws. A 75 should be testing exempt, as cars 20-25 years old are exempt in quite a few states. Or, you would only be held to 75 standards, which are signifigantly lower. Another possibility is registering the car and say its being stored in another county, if a neerby county doesnt have testing. Thats all I can think of...
Old Apr 6, 2001 | 02:19 PM
Jester's Avatar
I've tuned my carb to pass with 1/4 the legal limit, and NO emissions equipment at all. A double pumper on a 454 could pass just fine
Just open up a small vacuum leak or 3...and reset the idle speed to compensate. retard the timing a well if you must.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old Apr 6, 2001 | 04:04 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I just moved from Memphis... and I have a 74 454 car that passed with no emissions equipment whatsoever. I'm not even sure what it would have come with.
The spec for 75 is pretty easy to make. They only test you at idle, with a sniffer, no visual. My 83 Z28 with a 400 and a Holley double-pumper passed easily, with a cat and the AIR still hooked up.
If the car runs right (all 8 firing correctly, no oil burning, good fuel distribution, reasonable idle mixture) you won't have any trouble.
ICON Motorsports
Old Apr 7, 2001 | 10:26 PM
bubbz89's Avatar
Car: 1990 RS
thanks guys i didnt know that the standards were lower on older cars like that. thanks alot
Old Apr 25, 2001 | 08:03 AM
350HOZ28's Avatar
When I first moved to Colorado, I had no cat, smogpump and lacked all stock engine parts except for the intake manifold and my Q-jet. I had my open element K&N on, and I did add a cat as well. I then tuned down the primary side by setting the idle mixture screws down a bit and messed with the Idle Air Bleed and numerous other things. I ended up passing with 92 octane gas and a bottle of octane boost. If you live in California, the visual is hard to get by. Just make sure it is tuned good and everything should be fine. You get 15 days if you fail, to get it tuned right. Then you can go back through without paying again....well at least in Colorado you can.
Formerly known as 1984L69Z28
1984 Z28 - L69 optioned, 350HO w/ Trick Flow Heads, Drop Forged Lunati Crank, Crane Cam and 1.5 Roller Rockers, Stock Z28 Intake Manifold, Highly Tweaked Rochester Carb(700cfm), K&N Filter, ThermoMaster Chip w/ 160 Stat, Comp Headers, 3" Stainless Dual Exhaust w/ no Cat & Dynoflow Muffler, 4 wheel disc brakes, etc....
God bless us father, son, and holy ghost....whoever goes the fastest wins the most!!
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
