Holley DP vs. Avenger
Old Apr 25, 2001 | 11:34 PM
Changa2's Avatar
I'm building a 383 (about 400 HP) and am at a decision point on a Holley carb.
750 DP mech secondaries and manual choke vs. the new 770 Avenger, or mabe a DP with electric choke?
I want to be the first one to the grocery store but if my wife (on a rare occaision) takes it in the morning, I don't want to go out and start the car for her and then have her late for work, with a finicky DP.
BTW it will be a daily driver and we live in Mickigan not Florida or So Cal.
Would there be a noticeable difference in ET's at a bracket race?
I'm actually older than the Holley DP'er and I know there are a lot of strong opinions out there. I just don't have any personal hands on experience with one.
Would appreciate your comments.
Old Apr 26, 2001 | 10:27 AM
Polecat's Avatar
For all out power, the Holley 4779 750cfm carb. For more streetablility,electric choke, vacuum secondaries, the Avenger would be the one. But the 770 may be on the big side. The 670 is what Holley recommended to me.
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,TRW Forged pistons,10.7:1 compression,HPC Coated RPM intake, Speed Demon 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, Comp Cam 1.6 roller rockers, Comp Xtreme 284 cam,240/246@.050 with .540 lift,Crane pushrods,ATI damper,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with Hughes 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
Old Apr 26, 2001 | 01:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You should make your decision about DP vs VS based on your transmission type. If automatic, go VS. Properly tuned, you won't see any difference in ET.
The "finicky" part really isn't the DP but the choke. For a street driver, electric makes a lot more sense than manual, although trying to run a cool engine down the track can mess with an automatic choke (I just tie mine open with a twist tie when at the track - but that's a divorced type, not electric).
I don't know your wife, but I've been pleasantly surprised how adaptable the women that I know are. For instance, the first time my wife drove a stick was on our honeymoon - didn't kill it, didn't grind the gears, didn't over/under rev, etc. And, it had a DP with manual choke...
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" Hedders, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere w/open diff & slipping tranny. Daily driver while Camaro was being put together.
[This message has been edited by five7kid (edited April 26, 2001).]
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
86CamaroDan
Sep 29, 2015 10:08 PM
dusterbd
Sep 29, 2015 08:40 AM
makaveli09
Sep 15, 2015 10:43 AM
