Holley 750 DP vs Demon 750 Vac Sec, should i swap?
Old May 7, 2001 | 08:50 PM
Wayquick4u's Avatar
I pretty much hate my old holley 750 double pumper. It had been sitting for a while , i kitted/rebuilt it and it just seems like it only runs good at WOT, part throttle/cruising/idle sucks. I can get a demon 750 vac secondaries for 350, almost new....worth the swap?
Old May 7, 2001 | 11:30 PM
Demon Z28's Avatar
Car: 2001 Camaro SS
Engine: Almighty LS1
yup its worth it ... Demon carbs are proven things ... few people had bad luck with them but that was before they put them on the engine so its all good
Old May 8, 2001 | 12:31 AM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
A well tuned Holley will work just as well. I personally prefer Holley .
Big 454 72 Chevy Nova
383 86 Camaro Z28
10.5:1compression 186 casting Heads,234dur.488lift exh&int,Edelbrock performer intake, Holley750 vac.sec 400 crank,flat top pistons,edelbrock valve springs and lifters,tranny shift kit,2500 stall converter. Will install 3.73's later on and might go with a more aggresive cam.As of 4/01 added Hooker Headers,2.5inchpipes with 40 s. Flowmasters.Ignition upgrade include: MSD Coil and MSD module.
Old May 9, 2001 | 10:23 AM
greearhr's Avatar
I love my 750 Speed Demon but be prepared to tune it, same as a Holley. They seem to come set up for a very hot engine.
Bear Tracks
Old May 9, 2001 | 10:25 AM
greearhr's Avatar
I really like my 750 speed demon but be prepared to tune it, same as a Holley. It seemed to be set up for a very hot engine.
Bear Tracks
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
theurge
Aug 21, 2015 12:46 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
