need help with trunk lid
Old Mar 22, 2006 | 03:29 AM
sprslo92's Avatar
Car: 92 z-28 vert heritage edition
Engine: LT-1
Axle/Gears: 3.08 posi
for some reason my trunk is rubbing against my toneau cover and is now to the point where I cant open it. I already loosened th four bolts on the lid itself and pulled it out but it still wont line up. any ideas?
Old Mar 22, 2006 | 08:37 AM
plndtx's Avatar
Car: '92 Heritage Z28 Convertible
My car has 4 bolts holding the toneau cover on. It also has 4 bolts holding the trunk lid on. Have you tried loosening the toneau cover bolts and sliding it forward and loosening the trunk bolts and moving the trunk back?
Old Mar 22, 2006 | 09:57 AM
Trans It's Avatar
I posted this on another thread:
How old are your trunk-lid support struts? If they are weak, it can throw off the alignment of the lid. So make sure those are in good shape before you do any adjusting. I spent several hours adjusting mine last year, and sometime later replaced my struts and it changed the alignment. So I had to re-adjust it all over again. The funky hinges on these things have a little bit of play in them, so the strength or weakness of the struts can affect the fit.
Old Mar 22, 2006 | 01:25 PM
sprslo92's Avatar
Engine: LT-1
Thanks Trans it ill try that
Old Mar 22, 2006 | 01:26 PM
sprslo92's Avatar
Engine: LT-1
Old Mar 22, 2006 | 01:28 PM
sprslo92's Avatar
Engine: LT-1
sprslo92's Avatar
Engine: LT-1
1Aauto
Sponsored Vendors
Feb 8, 2017 03:09 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
chuck13
Sep 22, 2015 11:19 AM
