need help finding a...
Old May 26, 2006 | 09:10 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
that one strip of plasticy material the goes along behind the black parade top on the tonneu cover that keeps the weatherstripping from rubbing against the paint on the tonneu cover...
anybody know where i can get one? i had the tonneu cover repainted last year and didn't have one of those put back on and i'm getting the whole car repainted in a month and i want to put one of those back on this time around. any help? thanks guys/girls!
Old May 26, 2006 | 10:16 PM
sunbitz's Avatar
Car: 91 RS Convertible
Engine: 305 TBI
Hi,
I had mine repainted a few years back and it was no where to be found.
So they taped that area off on mine and added 5 coats of clear coat in that area. Why? So I could wet sand it out if it get's scuffed.
Another guy in town had a vert done recently... and they did not do it on his paint. His looks like mine except flat. There is a rim on both our cars where the rubber meets the paint.... but who cares? The plastic will only turn milky or crack after a few years.
Just keep up with the rubber and you'll be fine.
And it only gives you more reason to drive with the top down.
Old May 26, 2006 | 10:33 PM
BlueZee28's Avatar
thanks for the info. and as far as keeping the top down all the time...lets just say Missouri weather SUCKS
Old May 27, 2006 | 11:33 AM
AaronIROCZ's Avatar
Moderator/TGO Supporter
I have heard of people using 3m clear tape that is used to protect your lower portions of paint from rock chips. The only problem is it will have to be cut to fit, and it doesn't look easy.
Old May 27, 2006 | 01:32 PM
sunbitz's Avatar
Engine: 305 TBI
Side note....
The 3M tape would work, but would be hard to cut to form and get air bubbles out. I put a good carnuba wax on my car in that area and it did not leave a ring.
When there is only paint in that area.... it does scuff a tiny bit, but waxing brings it out again. It's just a little more maintenance.
Old May 27, 2006 | 03:29 PM
BlueZee28's Avatar
the paint guy said he coult put something similar to what you said, but it would have to small seams at the corners so it will lay flat. i might just have him put 2 more layers of clear coat on there so i can just buff/sand it out when need be
Old May 27, 2006 | 03:49 PM
sunbitz's Avatar
Engine: 305 TBI
It's kinda tough to see but maybe this gives you an idea.
Note the little black ring around the area... that's where the rubber meets the paint. My rubber is original to the car which dates back to 91. I hear you can get new rubber for this part which may eliminate the problem.
They taped the area off and then laid down an additional 3 coats of clear... the whole car has two coats of clear. Giving it 5 coats total in that area. Then sanded the edge to blend a bit more.
ChristinaMarie
Sep 11, 2015 06:28 PM
NiG
Sep 7, 2015 11:25 PM
Street Lethal
Sep 7, 2015 01:09 PM
