Rhinolining the floor?
Old Aug 1, 2006 | 04:22 PM
rover's Avatar
Car: 84 Z28 Matrix 3 convertible
Transmission: 700
I was near my car this weekend and ripped out the carpet. The floor was in good shape except for a couple small spots of surface rust under the paint. I was thinking of using the spray-on rhinolining on the floor before reinstalling carpet. I thought it would be a good noise insulator and protect the floor from rusting in the future. Has anyone done this? I don't think it would cause problems as long as I got all of the rust and moisture off first. Is this a good or bad idea?
Anyone else notice the 'Special Olympics Edition' in the 84 tech section production? lol
Old Aug 1, 2006 | 04:33 PM
j dezzy's Avatar
Car: 87 TA
I almost rhinolined my floor. but then I discovered POR15. I recommend you go with that it'll help strengthen the floor back up and it will never rust again.
Old Aug 1, 2006 | 04:42 PM
ABJ88's Avatar
Car: 1990 RS/2000 Z28
Engine: 5.0/5.7
Transmission: 4L60/4L60E
Axle/Gears: 10 bolt/3.23
hmmm. Rhinoliner will add a good amount of weight as for POR15, what's that?
Old Aug 1, 2006 | 04:48 PM
j dezzy's Avatar
Car: 87 TA
basicly POR 15 turns rusted metal rigid again. I saw it on an episode of Horsepower once. they took a piece of rusted steel, painted POR 15 over it and after it dried they beat it with a hammer and it didn't even dent. the stuff is amazing. if you put it directly over rust it will prevent it from rusting ever again. I havn't tried it on rust though. but I used it on the top and bottom of my new floor pans and I had my frame coated in it. It gets a little expensive though. about $100 a gallon. a quart goes a long way though. I did both sides of my floor pans with only a quart. so just buy it by the quart that way it won't dry out on you too. and just a warning...don't get this stuff on you...it takes months to wear off...seriously....I got some on my hands, and I scrubbed at it for almost 2 weeks before it was gone. a little bit that was on my arm wore off in about 2 months.
POR-15 Inc.
Old Aug 1, 2006 | 04:53 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
do a search for nelapse and the rhino lining he did it to his car a month or so ago with great results.
Old Aug 1, 2006 | 05:11 PM
rover's Avatar
Transmission: 700
OK the both options look good, now if I had more time and $. I think I am definately going to do one of the two before I put in carpet I just don't know when it will be.
As for the weight issue, I really don't care as rust prevention is my main concern.
I will have to use some of that Por15 on my landie in the future. I just sanded out some surface rust and painted in my door sill/wheel well this weekend, thankfully the rest of the car is aluminum.
Old Aug 1, 2006 | 11:47 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
there are other products that require less prep and are as effective as por-15. Personally I'm using a product called Rust bullet just because it's cheaper,easier,and just as effective.
LC2 TECH
Oct 13, 2015 11:53 PM
F-body-fan
Sep 19, 2015 09:02 PM
ctoledo0834
Sep 18, 2015 04:16 PM
IROCZDAVE (88-L98)
Sep 17, 2015 05:46 PM
3.8TransAM
Sep 17, 2015 02:16 PM
