park/wiring question
Old Apr 7, 2007 | 06:34 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Alright, my car was converted from auto to manual. Whoever did the swap just twisted the the park switch wires together. Past couple days, I installed the clutch start switch and wired it up. Well now, the top release switch wont work unless the clutch peddle is pushed in. I "kinda" understand why they had it tied into the park switch.
Well now I need to undo this. I see it is ground controlled, but where is the spot where they tied into this system at so I can undo it and ground it myself.
Old Apr 7, 2007 | 10:45 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Re: park/wiring question
When I swapped my vert to a manual trans, the only thing that changed was that I had to have the e-brake on to activate the tonneau
Might want to start there
-jason
Old Apr 8, 2007 | 09:13 AM
Dale's Avatar
Engine: 350 S-TPI
Did you swap wire harness from a manual? I see thats how it says manuals worked, but thats not working on my car.
Old Apr 8, 2007 | 11:05 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Nope, it was an auto harness. I searched for the schematic on this site I think. Then just tapped into the ebrake. Its been about a year or so though
-jason
Old Apr 9, 2007 | 08:34 AM
Dale's Avatar
Engine: 350 S-TPI
Alright, I'll prob have to pull out all the carpet and trace the wiring.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
