question about fender bolts
Car: 89 Camaro RS Convertible
Engine: 355 chevy power
Transmission: 5 speed manual
Axle/Gears: standard
ok i was wondering if you guys know if there is that bottom bolt on the fender that is usually close to the door where the now subframe connector is or if the fender is modified so that it doesnt need that bolt. As i need to change fenders and i think i would have one hell of a time removing the old subframe connector..
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: question about fender bolts
There is one you access from the door jamb. Then also remove the plastic liner in the fenderwell, and there is a screw to remove there.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
