How much is it worth?
Hi I was just wondering if you could help me figure out how much I can get for my 1992 firebird . It has 160k miles, runs good has an exh leak, its a convertable tops in good shape works perfect no body damage has a minor ding on the drivers door it has the honeycomb GTA wheels with almost new Nitto nt450 tires, automatic trans, interior is not so good, the steering column is broken they tried to steel it whem I had 17 inch KMC stealth rims wich i am including in the sale the chrome rims have 1 broken center cap and 2 bad tires, it has a 305 TBI engine, I replaced the steering wheel with a grant but have the original. the drivers door was sagging so i replaced the pins and bushings with greaseable ones the door dosent quite sit flush needs some work on the striker and latch, it has a flowemaster muffler and crome exh tips, electric windows.
I also have a 1991 camaro rs t top 305 tbi 5 speed with 200k the engine is a gm crate 305 stock with like 30k on the engine it has a centerforce clutch and flywheel, it has z28 ground effects and I still have the hig rise spoiler all that is missing is the door panels and the stereo. I also have a new hood for the firebird, how much do you guys think I can get for all this?
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: How much is it worth?
I would start by looking at KBB, Edmunds, NADA etc, Vehix, Automotive news etc, see what they are estimating the car at. It seems that those are usually low, so then I would look at Cars.com & autotrader.com, look for cars similar to yours... and start from there...
With the TBI, all stock I would think the vert would be around $2500 to $5000 depending on the overall condition... The 91 camaro, 200K YOur in the ballpark of $1000. Add the little things on... REalistcly I think you might be lucky to get $5000 for everything as you described them... Its hard to say as everywhere is different. A Firebird in MI goes for more than a Firebird in SC... go fig
John
John
Car: 2002 zr2 Blazer 88 Iroc convertable
Engine: 305 T.P.I.
put it on craigslist, start high and work down. when you get the e-mails flowin in you got the #. Good Luck!
skinny z
Oct 5, 2015 06:23 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
