89 rs convertible latch actuator
Old Oct 26, 2010 | 07:15 AM
integritybrad's Avatar
Does anyone know where to find replacement actuators for a convertible top? Mine work slightly but have corosion on the piston and aren't strong enough to release the latch.
Old Oct 27, 2010 | 12:22 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: 89 rs convertible latch actuator
I suppose you're referring to the tonneau release solenoids. I have used ones available. Do they fire, but not release the J-hooks? It could be that the body has gotten a little tweaked with time and you just need to adjust the J-hooks. You can loosen the nuts mounting the J-hooks and put shims behind them. Or replace the J-hooks if they are severely worn. I've never seen weak solenoids. The ones I find always fire strongly.
Lon
Old Oct 27, 2010 | 12:40 PM
One side fires but does not have enough strength to release the hook. The other side won't fire at all. It has rust on the piston which I have been able to free up somewhat with PB Blaster and sand paper, but it still won't fire.
Old Oct 27, 2010 | 05:25 PM
lonsal's Avatar
Your solution is on the way.
Lon
84LsxZ28
May 17, 2020 02:21 PM
FormulasOnly
Jul 23, 2018 08:47 AM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
Formula8r89
Sep 22, 2015 04:24 PM
camarohelp
Sep 12, 2015 05:45 PM
