Stock weight?
Old Dec 12, 2011 | 08:12 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Stock weight?
What is the stock weight of a vert compared to a hard top?
Old Dec 15, 2011 | 08:18 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Re: Stock weight?
I meant to get you your answer today but I forgot to look at the weight placard on my vert when I was working on it to install new shocks. The car is garaged 30 miles from my house and I have had it laid up for suspension work.
I'll get the info on my next "work day" (struts coming UPS tomorrow) and compare it to the 91 spec sheet I have from Pontiac. The spec sheets don't include the vert, but they do have the coupe weight and info to add or subtract pounds based on equipment. I will calculate a coupe weight with my convertible options and let you know unless another member already has the answer for you.
Old Dec 15, 2011 | 08:30 PM
insomniac's Avatar
Engine: 5.7 L98
Re: Stock weight?
thanks man
Old Dec 16, 2011 | 05:00 PM
tavert91's Avatar
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Re: Stock weight?
Got my info. It tells me that my TA has a curb weight of 3567 lbs. The Pontiac spec sheets say a 91 TA coupe with the same options weighs 3617 lbs. If you believe these numbers, the convertible is 50 lbs lighter.
However, there were no add-on weights shown for wheels/tires and power seats which came standard on the convertibles. Not sure if they make much of a difference but I added 20 lbs for the seat's power/motor modules and nothing for the gatorback tires thinking that the standard TA tires were about the same weight.
By the way, an old Car and Driver article from Aug of 1991 listed the same curb weight for the convertible so I think my number is correct. It would be nice if someone with a 91 TA coupe could validate the 3617 number for the coupe.
Old Jan 12, 2012 | 05:23 PM
insomniac's Avatar
Engine: 5.7 L98
Re: Stock weight?
i was always under the impression the vert was heavier then the coupe...
customblackbird
Aug 15, 2021 10:16 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Genopsyde
Oct 7, 2015 08:35 PM
camaro71633
Sep 1, 2015 10:24 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
