Spring ?
Old Oct 29, 2012 | 12:36 PM
Eric Krutilek's Avatar
Spring ?
Do the 1991 Pontiac convertibles have computer controlled suspension?
Old Oct 29, 2012 | 02:26 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: Spring ?
Not any that are stock as far as I ever heard. The RPO codes often mention computer "selected" springs for a car.
Old Oct 29, 2012 | 03:27 PM
Re: Spring ?
My RPO shows every wheel with one. What does this mean?
I would assume this is what they are referring to.
Old Oct 29, 2012 | 04:20 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Spring ?
It means that the computer selected the springs to install on the car based on the combined weight of all the installed options.
Old Oct 29, 2012 | 04:31 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: Spring ?
It's interesting that there is an RPO for each corner option, so four RPO codes to define a car. I assume that they are just selecting a spring that has a slightly different installed height and not a different rate. I wonder if they match each side or if, say, the two fronts could be different.
Old Oct 29, 2012 | 04:58 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Spring ?
Even though they're matched, LH/RH springs are different parts so it makes sense that they have their own codes.
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
