Door weatherstriping
Old Feb 13, 2014 | 05:00 PM
Wild Weasel's Avatar
Car: 1989 RS Drop-Top
Engine: 305 TBI
Quick question. Does the door weather-strip for the t-top fit the vert?
Can't find the answer in search. Just need the door strips.
Old Feb 13, 2014 | 06:10 PM
chris schaner's Avatar
Car: 1990 irocz camaro
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.42 posi disc 10 bolt
Re: Door weatherstriping
yes all doors are the same
Old Feb 14, 2014 | 04:02 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Are you talking around the sheet metal to sheet metal? door jamb? They yes like Chris said. The window seals are different obviously
Old Feb 14, 2014 | 04:46 PM
Engine: 305 TBI
just the metal to metal. I am trying to get the doors to shut a little more quite. Now it sounds like slamming a tin can.
Old Feb 14, 2014 | 10:22 PM
okfoz's Avatar
Be aware that some weatherstrip needs some break in more than others... if you can afford it, get the GM stuff... I got one of the aftermarket ones and it was ok... a little hard to close for a while. Do a little research first.
Also not much is going to make the doors shut like a new car... New cars have a way superior latching mech that makes them quieter than they ever were in 1989 even new...
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
