Tired of manual torneau release need to rewire
Car: 88 Camaro IROCZ Convertible
Engine: 305 tbi
Transmission: auto
Hey guys
So ever since i got my camaro last fall i bin trying to figure out if my torneau release switch in the middle of the two window buttons work..all it seems to do is flash a light in the trunk..is it wired wrong or is that a safety or something or is it just wired to the trunk? Has anyone ever had this similar issue?
88vert , i see the solenoids behind the rear speaker compartments but nothing happens...any help would be greatful
Thx
Thx
Axle/Gears: 3.45, 3.27, 3.27
Re: Tired of manual torneau release need to rewire
Check that it is grounded adjacent to the parking brake under the center console.
Lon
Lon
Car: 89 Iroc Convertible
My solenoids didn't work until I installed the plunger switch on my hatch pulldown.Now I just have to figure out why they don't release all the way
Also clean the latch with WD40 and blow if off with compressed air. Then spray with silicone.
Lon
Engine: 305 tbi
Transmission: auto
Sorry, no I was not referring to that switch. I do have a few of those in stock on my web site. Those were only used on convertibles to tell the tonneau that the trunk pull-down is closed and allow the tonneau to open with the switch. If that switch is unplugged it would be a reason why the solenoids won't fire. I thought from your descriotion that you got the tonneau release solenoids to fire, but the tonneau latch was not releasing.
http://www.top-downsolutions.com/hat...product_id=216
Lon
Lon
Engine: 305 tbi
Transmission: auto
No that was "my82roc" who said that , mine wont fire at all, trunk light jus flashes when i hit the middle switch
Engine: 305 tbi
Transmission: auto
i dont know if anyones wiring is as screwed as mine cause when i hit the latch button the light comes on cause its wired in parallel with the solenoid on the passenger side, i guess i gotta take apart the center console and do some more searching and tracing probly check out the relay but then again i know the light gets power and i dont know why the solenoids wouldnt mayb they need replacing
Engine: 305 tbi
Transmission: auto
Fixed it , pretty stupid issue , who ever had this b4 plugged the connector for the light switch in the hatch safety switch and vice versa , i never knew and never recognized they were the same type of plug until i unplugged it. Thanks for the help
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
