Tonneu Latch Upgrade Kit from Hawk's (anyone tried it)
Old Apr 12, 2016 | 03:35 PM
88IROCvertZ's Avatar
Car: 1988 IROC Z Convertible
Engine: 305 TPI (LB9)
Transmission: 700 R4
Axle/Gears: G80 GU2
I was wondering if anyone tried out this 87-88 upgrade latch kit from Hawks. The plastic piece that holds the lever on my 88 cracked and I have it fixed for now, but it's a pretty poor design. I read someone else on here way back snapped their's off by using a little too much pressure which I've heard is all too common.
Mine works fine, but if someone else were to try and use it they might snap it off. I'd like the car to work properly for anyone.
The 89-92 verts have a handle that looks more like the inside door handles and seems like a better design.
Anyone try it?
Do they give you instructions? How difficult is it to do?
I'm assuming you can't use the original cable and there are some other parts as well to complete the switch.
Tried to call Hawk's but they are tough to reach.
http://www.hawksthirdgenparts.com/ca...h-upgrade-kit/
Old Aug 11, 2016 | 04:34 PM
irocdan's Avatar
Car: 88 Iroc vert
Engine: 305 tpi. cts-v brakes
Transmission: Tremec T-56
Re: Tonneu Latch Upgrade Kit from Hawk's (anyone tried it)
Damn, thats expensive
Old Oct 11, 2016 | 03:47 AM
IROCNParts's Avatar
Car: 1988 IROC-Z Convertible
Engine: 408 Stroker Turbo, TPIS Mini Ram
Transmission: Magnum t-56
Axle/Gears: Ford 9" 3.55
I did it in my 88. Hasn't failed once. Its a bit of money but will last
89irocz355
Mar 28, 2018 08:24 PM
89irocz355
26
Sep 12, 2016 01:28 PM
89irocz355
Exterior Parts for Sale
18
Apr 11, 2016 10:17 PM
89irocz355
Apr 4, 2016 12:05 PM
89irocz355
Mar 27, 2016 09:52 AM
