Convertible top adjustment.
Transmission: World Class T-5
Axle/Gears: BW 3.45
Anyone have a schematic on how to adjust the front bow/pins on a convertible top? Searched, but didn't find anything.
Previous owner of my '87 said that they always had a problem with the top since new. This car here:https://www.thirdgen.org/forums/hist...nvertible.html That's probably why it's spent the past 30 years folded down.
First day I got it, I couldn't get the top to latch, ie., getting the pins and holes lined up until I loosened the 4 adjusting bolts in the rear. And even then it was tough.
Better now, but still takes a lot of finagling to line the front pins up with the windshield. There has to be a way to improve it.
Any words of wisdom or schematics?
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Re: Convertible top adjustment.
Did you leave the back pin undone until you get the front arms locked in? This helps.
Here you go.
Here you go.
Axle/Gears: BW 3.45
Axle/Gears: BW 3.45
"I think", the top needs to be moved back a bit, however the adjustment bolts are at their full travel.
This from the stickey in this forum:
Where is the UPSTOP and DOWNSTOP? Anyone have a pic of that?
The secret may lie in Tootie's link.......
Adjustment
UPSTOP
The upstops may be adjusted to obtain proper alignment between the top latch guide pins and the windshield header receivers.
Lower the top. Loosen the upstop jam nut and turn screw clockwise.
Raise and latch the top.
Raise No. 5 bow to the full vertical position.
Turn the upstops counterclockwise until they contact the linkage.
Unlatch and lower the top. Tighten the upstop jam nut while holding the upstop from turning.
Raise the top and inspect the alignment of the top latch guide pins to the header receivers.
DOWNSTOP
The downstops can be adjusted for proper clearance between the main rail and No. 4 bow when the top is lowered completely. The downstops have right angle bends and face outward.
Loosen the downstops nuts and adjust as required.
Tighten the downstop nuts while holding downstops in position.
Lower the top and inspect the clearance between the main rail and the No. 4 bow. Also inspect the clearance of the tonneau panel.
UPSTOP
DOWNSTOP
Axle/Gears: BW 3.45
Thanks Tootie Pang, I think I did it with the help of your pdf!
Axle/Gears: 3.45, 3.27, 3.27
Latch front pins first, then close the #5 bow by letting it drop down and latch the pin. If the rear pin won't latch, the top is too tight on the frame.
Lon
Lon
