Need some help
Subscribe
Sep 17, 2017 | 05:35 PM
So these things broke off my convertible frame. Id like to know what these are for and if it effects the way the top opens and closes. Also where could i find these to replace it
Reply 0
Sep 17, 2017 | 09:36 PM
Re: Need some help
Yes , they are called flip rods and they flip that bow over to help raise and lower the top.
Top down solutions makes and sells these
Reply 0
Sep 17, 2017 | 10:17 PM
Re: Need some help
Ooooh ok. Thanks for the info 86gn
Reply 0
Sep 19, 2017 | 06:17 PM
Re: Need some help
Got mine from Top Down Solutions. they look good and work great.
Reply 0
Sep 19, 2017 | 09:09 PM
Re: Need some help
Thanks for the info i hope they work well when i get them��
Reply 0
Sep 25, 2017 | 10:49 PM
Re: Need some help
Lon at Top Down Solutions will be able to help you solve this issue.
Reply 0
Sep 26, 2017 | 10:17 PM
Re: Need some help
Yes I sell an improved version of the Flip Rods. TDS 104121, $65 for a pair, or $35 for one. The one in the foreground of the attached photo link is the OEM version which is prone to breakage. My version is shown as the pair in the background. My improved version has a ball and socket joint which replaces the bent and threaded 90 degrees of the OEM style.
Lon
http://www.top-downsolutions.com/ima...sm-500x500.jpg
Reply 0
Sep 28, 2017 | 12:37 PM
Re: Need some help
Lonsal so would you recommend that I replace those when I replace my top? I purchased the top with the glass window but I still need to find someone to install it for me. I will go to your site to see what else you offer, I need the front trim and maybe a headliner.
Reply 0
Sep 28, 2017 | 11:23 PM
Re: Need some help
Replace the flip rods if they are missing or broken.
Lon Salgren
Reply 0
Subscribe
