Hawks Convertible Header Panel
Old May 14, 2018 | 06:03 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
Has anyone bought an 89-92 convertible header panel from Hawks? If so, how did you find the fit and quality. thanks in advance.
Old May 22, 2018 | 11:13 PM
1992 Trans Am's Avatar
Car: 1992 Pontiac Trans Am Convertible
Engine: 5.0L 305ci TPI
Transmission: 5 Speed Manual, World Class T-5
Axle/Gears: 3.08
Re: Hawks Convertible Header Panel
I’m interested in the answer to this question too.
Old May 23, 2018 | 01:00 AM
Convertible header panel---Hawks reproduction. Anyone tried this? Opinions? thanks anyone.
Old May 25, 2018 | 10:44 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I have one on my 89, it is an 8 out of 10, better than the cracked one I had. The only thing is it is more glossy than the original... I need to paint it semigloss, but never have.
If you can find a perfect used original, that might be a better way, BUT those are hard to find.
John
Old May 26, 2018 | 10:24 AM
Axle/Gears: 3.08
Thanks for the feedback. It sucks that the sheen is different. I’ll hold out as long as possible for an original one.
John
Old May 29, 2018 | 04:28 PM
okfoz's Avatar
I got the very first ones off their molds... With that said, I just got a set of the seat belt cap covers, and the sheen is spot on. I suspect they may have corrected the sheen issue. As my parts are 10 years old.
Old Jun 3, 2018 | 03:24 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I have one sitting in the garage, haven't installed it yet. I bought it along with new plastic that goes on the top of the door panel along the window, sill panels and dash. All of the reproduction pieces that have the haircell texture are different from stock under close exam. If you are just looking at it from a standing height at a car show it is unnoticeable but if you put an original and a reproduction side by side and really look you can tell it's different.
The header piece isn't really expensive but if it is cracked and still stable I would just put some plastic epoxy on the crack and cover the panel in black leather or leatherette. I did that with my original header panel since it was cracked and it looked great. The fire ate it though.
1992 Trans Am
Interior Parts Wanted
May 15, 2018 10:04 AM
acesena4
Jul 11, 2017 12:00 AM
Ragtop Man
Convertibles
Dec 6, 2016 01:30 PM
90-irocdx3
May 24, 2015 11:28 PM
hawksthirdgen
Sponsored Vendors
Sep 24, 2010 06:15 PM
