Overheating After Running Only A Few Min.
Old Jun 9, 2002 | 09:25 PM
camaro1982's Avatar
can anyone hear give me any ideas on why my engine is overheating after only a few mins. of running? first off i must say the this is a new rebuilt 305 1982 camaro and im trying to set the timming and brake my new cam in but the damn thing gets so hot before i get the chance to do anything. i checked the thermostat by boiling it in water in a pot and checking the temp and it opens at about 200-201* so thats not the problem i guess. maybe still alot of air in the system? if so should i run a hose in the radiator and run the car with the heater hose disconnected and let the system flush out the air? and would the fact that i removed the a/c system have an effect on the overheating? please if anybody has any suggestions
Old Jun 9, 2002 | 11:25 PM
Desert86Roc's Avatar
Did you use a new or old waterpump? Is your water pump rotating the correct direction? Can you verify that water is moving through the radiator? Pinch off your heater hose coming from the manifold or waterpump. Does the flow through the radiator increase?
Old Jun 9, 2002 | 11:38 PM
camaro1982's Avatar
the water pump is brand new, right direction? why would it flow in opposite direction?
Old Jun 10, 2002 | 01:43 AM
breathment's Avatar
maybe u are running really lean. u said u were still trying to get ur timming adjusted.. our pumps flow reverse direction.. make sure ur pump IS correct for ur car.. also make sure ur fan is working properly
Old Jun 10, 2002 | 03:56 PM
FiReBReTHa's Avatar
could the heater core have anything to do with it???
Old Jun 10, 2002 | 05:22 PM
camaro1982's Avatar
ok i got my timming adjusted maybe im just overeacting 'cause after reading so many threads about our cars here i guess they were meant to run that hot. but man 220-250* seems really hot for any engine. im just afraid of blowing something under the hood. im going to install an aftermarket temp gauge and see how accurate the stock dash gauge really is. im also going to invest in a new radiator and electric fan as i dont trust my summit flex fan enough to cool the engine. how can you be sure the heater core is bad? everything is so hot under the hood and i mean everything..all hose are hotter than ****, my fan is hot, so is my flex fan blades sheesh. i still get alot of heat blowing thru my vents when i turn on the heater. :hail:
eightsixseven
Dec 16, 2024 01:50 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
mustangman65_79
Sep 1, 2015 03:51 PM
perZ
Aug 21, 2015 05:51 PM
jbd1969
Aug 17, 2015 07:06 PM
