Fan Switch doesn't fit?
Old Jun 12, 2002 | 10:25 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I bought a Hypertech fan switch/coolant temperature sensor and when I went to install it, it didn't fit. The end that plugs into the engine was too large in diameter. Also, the connector they supplied had no where to be plugged into on the existing wire. I also have two wires near the switch- one was connected to the switch, and the other was not. The one that was not looked to be the same as the one that was connected, only broken. Any reason why I have two wires for one switch? Any reason why the thing won't fit? It says it works on 5.0/5.7L TPI Vettes, Camaros, and Birds.
Any help is appreciated, thank you.
Old Jun 13, 2002 | 01:42 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Got me
^Bump
I wired a manual fan switch, it works great
Old Jun 13, 2002 | 01:48 PM
Car: 1989 IROC-Z
Engine: 383 stroker
Okay, here's the piece that came out of where I was told the fan switch should be. What is it? Is it a knock sensor? I thought the knock sensor was about 10 inches above the fan switch.
Old Jun 13, 2002 | 02:02 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
That looks like your Knock sensor. You Knock sensor is 10 inches below the fan switch. The fan switch is on the head itself.
Old Jun 13, 2002 | 02:17 PM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
It is the knock sensor. Fan switch is an all brass unit.
Old Jun 13, 2002 | 05:12 PM
Car: 1989 IROC-Z
Engine: 383 stroker
Yep, got the fan switch out and replaced. Fans are working well now. Thanks guys
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Dkelz313
Apr 7, 2016 10:38 PM
TA8487
Aug 16, 2015 12:21 PM
matthew911
Aug 12, 2015 09:38 AM
