Hooking secondary fan switch up directly
Old Jun 26, 2002 | 04:17 PM
Don_89Iroc's Avatar
okay tell me if this is correct, to hook up the secondary fan switch to a toggle switch....i need to find the wire that goes into the sensor wich is located on the passenger side in the head or block, take some wire connect the 2 wires run the wire into my car and splice the wire with a toggle switch, then i can turn my secondary fan on and off when i want??? is this the way to do it? if not please tell me how i can do this Thanks -Don
Old Jun 26, 2002 | 10:54 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Here's all you need to do, keep in mind, you can use whatever color wire you wish to run to the switch & fan switch wire colors varied thru the years so I used black, they can be blue, black, grey or some other color I've yet to see but, as long as you find the fan switch, wire color is irrelevant.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
krisner89
Oct 10, 2015 06:03 AM
Ducati900ss
Sep 2, 2015 09:05 AM
TA8487
Aug 16, 2015 12:21 PM
