400 SBC overheating myth dismissed
Old Jul 7, 2002 | 09:12 AM
Blackened's Avatar
I've always heard that 400 SBCs overheat. And they would overheat even MORE if you don't drill out the steam holes in the head. Well, I have one without the steam holes drilled out. It was a race block so whoever had it before plugged the holes. I didn't drill them because I was afraid I might damage the block. Now in intense Nevada heat (106-110 degrees) my engine runs at 180 all the time. Goes up to 200 WITH the AC on. That's not bad considering our cars run at 220 most of the time. This is with two fans running all the time. In the winter I have to keep the fans off to get it even go up to 160.
Just a little FYI for people that are scared to put a 400 in their car because it might overheat. I'm sure if you drill the steam holes out it would run even cooler. Now go look for a 400 and make your ride faster TODAY!
Old Jul 7, 2002 | 02:28 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
Re: 400 SBC overheating myth dismissed
i would if i had the money
Old Jul 7, 2002 | 07:06 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
Thanks Blacken:
YOU INSPIRED ME....
I went out today and bought a SBC 400 for $50.00. What type of setup are you running? i.e. Heads, Piston, Compression, Carb, and Intake.
Old Jul 13, 2002 | 10:14 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
i 'm rebuilding a 400 also. not sure which 400 heads i've got, but i'm not sure if the steam holes have been drilled out yet. any pics of what im lookin for? thanks. cant wait to get that beat old 305 out and this baby in......
Old Jul 15, 2002 | 01:26 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Hey DTL504...kind of looks like you could take the components you have on your 283 and swap them directly onto your 406 (You should do steam holes on a street engine...no matter what) and have a pretty good setup.
Lots of torque...something you don't have now.
Old Jul 18, 2002 | 05:37 PM
ChevyThunder86's Avatar
$50? where can i get one of those deals!
sheachopper
Jul 31, 2019 11:27 AM
gixxer92
May 18, 2017 11:20 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Bradsaundry
Oct 7, 2015 04:35 PM
