help locating the fan relay - 92RS 305
Old Jul 12, 2002 | 01:30 PM
nkrug's Avatar
Could anyone tell me where that is at? It must be out, I have to turn the AC on to get the fan to kick in.
Or, it would be cool to have the fan on a toggle switch where I can just turn it on when needed. Or better yet, have it hot when the key is turned on...Any ideas on any of this?(in stupid terms)
Thanks!
Old Jul 12, 2002 | 11:31 PM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
As your sitting in the car, the relays are located in the left corner of the engine bay right against the firewall. Your fuel pump relay is there as well. Hope that helps.
Old Jul 13, 2002 | 07:18 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
The primary fan relay is usually located down from the radiator cap mounted to the metalwork around the radiator.
Old Jul 15, 2002 | 02:51 PM
WS6 Berlinetta's Avatar
In my '92 TBI Firebird the fan switch in the pass side head went bad and I had the same problem. All you have to do is ground that wire to turn the fan on, it's connected to the green/white wire on the A/C compressor so the relay should be good. You can hook it to a switch to make it switchable or if you just ground it it will turn on when you put the key in run. I hooked mine up to an SLP fan switch from a 4th gen.
R
Old Jul 16, 2002 | 04:10 PM
nkrug's Avatar
Thank's for the help, everybody.
Glowsock
Jul 24, 2025 03:15 PM
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
tero
Aug 15, 2015 02:47 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
