where are the temp switches?????????
Old Jul 13, 2002 | 08:01 AM
1991rscamarodem's Avatar
ok guys, i have a 88 iroc with a 5.7 in it and dual fans. i would like to know if i can just switch the secondary temp switch with a primary one and have both turn on at the same time without having to wire the grey and green/white wires together?? the other question is where the heck are the temp switches for teh secondary and primary fans located?????????
Old Jul 14, 2002 | 01:16 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
One is the coolant temp sensor, in the front of the manifold, the other is located between #6 and 8 cylinder on the passanger side cyl head.
Old Jul 14, 2002 | 01:43 PM
MdFormula350's Avatar
u usually do not need both fans running to cool down the engine, if u r looking for reduced engine temp just buy a lower fan switch for the passengers fan, and a lower thermostat like 180, and you should run around 180 to 200.
Bubbajones_ya
Jul 6, 2024 08:32 PM
tommy z-28
Oct 6, 2015 10:58 PM
86IROC112
Sep 11, 2015 04:04 PM
Randomtask2
Sep 10, 2015 08:37 AM
85Special
Sep 3, 2015 04:21 PM
