Ownners of the Griffin 31x19 and GM crate 350 question
I have will be getting this radiator
http://www.jegs.com/cgi-bin/ncommerc...85&prmenbr=361
(6th one down)
475-125272-X
and I have a GM crate 350 with a stock waterpump in my TA
I am trying to find out how much antifreeze I am going to need to fill the system. Thanks
(6th one down)
475-125272-X
Dude. Relax. Go get yourself three 1 gallon jugs of antifreeze. Add a gallon of antifreeze, then a gallon of water, gallon of antifreeze, gallon of water... When you can start to see it fill up to the top, start up your car, turn on your heater to full blast hot, and quickly get out to do some more filling. Keep it 50/50 and you'll be just fine.
S.
S.
Not annoying, you just seem to be working yourself into a froth over having to have an exact amount of antifreeze to work with. I'm just saying to relax about it, that's all. After all, it's not like you can 'overfill' a radiator or anything, and if you buy too much antifreeze, you'll eventually use it. No biggie.
S.
S.
I just want to be sure that I can finish the job in a day with no hassles. I need the car to drive to work. I just want to make sure I have absolutly everything I need before I start.
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
