wires from fan?
Old Aug 21, 2002 | 10:47 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
wires from fan?
ok guys my fan doesn;t come on after my tbi to carb swap and i can't find an answer why in the search so i need to knwo where the 2 wires from the fan go. one is black and the other is black with a pink stripe.i know if i touch the black with a pink stripe one to the battery the fan will run. well thanks guys. oh yea the sensor in the head on the passengerside controls the fan right?
Old Aug 22, 2002 | 05:25 AM
1991rsblue's Avatar
yeah, the relay for the fan is on the drivers side wall. it has a black/red, blue, brown, and maybe a nother color i'll try to find a diagnostic schematic of it for ya. do you have all the woiring hooked up right from the ecm to the relays, and from the relays to the fan? check over again. see if the computers if you changed them are compatible.
Old Aug 22, 2002 | 05:26 AM
1991rsblue's Avatar
coolant fan schematic
here try this....
Old Aug 22, 2002 | 05:33 AM
1991rsblue's Avatar
try this again
hopefully it'll work now
Old Aug 22, 2002 | 05:38 AM
1991rsblue's Avatar
grrrrr
grrrrr
Old Aug 22, 2002 | 05:41 AM
1991rsblue's Avatar
welp, it won't work so if anyone else can get the ****in computer to work right put one up. the wiring is like this. the relay has a orange, tan, black/red, and a dark green.
dark green-ecm
black/red- fan
orange or red-hot(fuseable link)
tan- fuse block(hot in run)
hope that helps a little. until i can get this stupid thing to work that's all i got.
Old Aug 22, 2002 | 11:47 AM
Car: 89 Formula
Engine: Carbed 5.7
wel i have no computer cause i have a carb and not tbi anymore so wut do i do now?
Old Aug 22, 2002 | 03:42 PM
1991rsblue's Avatar
that's prolly whyit won't work. usually the ecm grounds the green wire and that turns on the fan by making a complete ciruit. if you have no ecm then the car doesn't know when the fan should turn on. your best bet would be to hook up a seperate toggle switch for the fan so you can turn it on manually.
Old Aug 22, 2002 | 05:36 PM
breathment's Avatar
you could probably get u a fan switch that will turn ur fan on around 185 or 210 or whenever depending on what what thermostate u have... and have that take the place of the ECU
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
krisner89
Oct 10, 2015 06:03 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
