electric fans
Old Aug 31, 2002 | 09:43 AM
irontrain's Avatar
electric fans
We have a 1992 Camaro Z28.The passenger side fan comes on almost immediatly,but the drivers side does'nt come on at all.Where should I start trying to fix this?
Old Sep 1, 2002 | 08:22 PM
MdFormula350's Avatar
well either fan should come on right away unless someone has been messing around with wiring..
the fan relays on my car were on the drivers side firewall, to the right in the master cylinder..
the diagram should help alot..
Old Sep 1, 2002 | 08:24 PM
this should help also..
Old Sep 2, 2002 | 08:35 AM
SpeedJunkie's Avatar
Car: 88 IROC
Ok so if i put those swithes in
1-i could control when i want them to come on, but only if the ignition is on?
2-the computer will also ground them when it is susposed too even if I have the switch grounded or not?
So all this really does is ground the relays in another spot just like the computer does?
Old Sep 2, 2002 | 12:18 PM
JOHN/88IROCZ's Avatar
You can check if the relays are good by taking an ohm meter and test the ohms between terminals D and F of the coil > than 50 good < 50 best to replace. Then you will know if they are bad before you replace them. If they are good then you can look elsewhere for the problem instead of a wasted trip to the parts store. Hope this helps John
sheachopper
Jul 31, 2019 11:27 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
Fanatic1074
Oct 2, 2015 03:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
