Mounting Dual Fans
Subscribe
Sep 24, 2002 | 09:42 PM
How do you mount the dual radiator fans?
Reply 0
Sep 24, 2002 | 11:18 PM
Mounting the fans is pretty simple. Here is a list of the major pieces.
Motors
Fans
Upper and Lower shrouds
2 "Y" shaped brackets (mounts motors)
Wiring
If you do not have the parts then I would recommend a junkyard or Ebay. The shrouds can be picked up at a dealer pretty cheap but the fan blades cost $50 a piece and you don't even want to know what the motors cost. As far as wiring goes, if you are converting from a manual fan like me then I found that an adjustable fan relay works great for about $50. You should be able to find one at your local parts store. Putting everything together it should be pretty self explanitory once you get everything in front of you. Just replace your old shrouds with the new ones and mount the motors w/fans to the "Y" brackets. From here simply bolt the "Y" brackets between the two shrounds and hook up the wiring. I hope this helped some.
Troy
Reply 0
Oct 13, 2002 | 11:30 PM
i am going to use tranny cooler type plastiv ties with some washers.
Reply 0
Subscribe
