Prestone Super Anti Rust
Old Sep 30, 2002 | 10:31 AM
dp149's Avatar
Has anyone used Prestone super anti rust ? my TA doesn't move that much so I decided to add some of this to the cooling system to help protect against corrosion. Prior to adding antifreeze was a nice green, no rust and protection to -35 degrees.
I added this anti-rust and it made the antifreeze a cloudy brown. Does anybody know if this will turn back to the nice green again ? Or did I screw up and should flush my system.
any advice ?
Old Oct 1, 2002 | 09:43 AM
Sciguyjim's Avatar
I never heard of that happening before. What color was the antirust stuff before you added it? How old was the antifreeze in your car? This wasn't some additive for use with the orange, long life antifreeze, was it?
If I saw that happen, I'd flush the system to be on the safe side. If the color becomes green again, I think it would be because the brown stuff settled out everywhere. You can see if the brown stuff consists of particles which can settle out by making a funnel out of some porous paper like newspaper. Put some of the brown antifreeze into the funnel then let it seep out. Compare the color after it comes out, and look inside the funnel for brown particles or "mud". If it's there, flush the system.
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Zell1luk
Sep 29, 2015 10:36 AM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
