Cooling fan turn on?
Subscribe
Oct 1, 2002 | 05:44 PM
I was wondering what I need to turn my cooling fan on without a toggle switch. My car has an electric fan and its not wired corectly. I want to get an aftermarket set up for it like the one Jegs offers from Flex-a-lite, PN 400-31147. I just dont know what all I would need to make this happen. I dont know if that switch needs to be hooked up to a realy or something like that or not. I just want some suggestions as what to do with it. I want it to turn the fan on at about 200 or maybe even 190 because it seems to run a little better when its cooler.
Reply 0
Oct 5, 2002 | 07:57 PM
try this..
Reply 0
Oct 5, 2002 | 09:20 PM
Thank you that helps alot but its the same for the ones with single fans right? Just take the secondary fan circuit out.
Reply 0
Oct 5, 2002 | 09:23 PM
well with a single fan.. u just combine the two ciruits together. (all the a\c switches and stuff) into one ciruit.. but yes its pretty much the same..
Reply 0
Oct 6, 2002 | 02:38 PM
when running a voltage like 12 volts and a current load of quite a few amps its always a good idea to use relays..
Reply 0
Subscribe
