Cannot keep my T/A from overheating, HELP ME!!
Car: 71 Skylark
Engine: BBB-430
Transmission: M20
I have an 85 T/A, with a Big BLock Buick 430, 10.25:1 compression, .464, .488" lift,
31x19 dual 1 1/4" cores
2 12" perma tech fans, pulling 1650 cfm
a new air dam
A new working thermostat,
hoses arenot restricted, or kinked in anyway
water pump is brand new,
runs on 94 and lead substitute, and doesn't ping at all.
timing is set correctly as well
it overheats at idle, and when driving. any suggestions? thank you Joe Hurley
a new air dam
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Throw away the perma tech fans and get the dual 11" Spal or Be-Cool fans. They are the same fans.
I got mine for $239 from The Car Shop
2012sergen11
Oct 13, 2015 07:38 PM
